A/C blowing hot air
192,354 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
CHRISTOPHER IVAN ROEDER
  • 156 POSTS
My A/C isn't working, it's blowing hot air out and I'm not sure where I start to diagnose. I can tell you it's not low on refrigerant at all. what is recommended and what process do most people use?
Aug 12, 2019 at 5:34 AM
Good afternoon,
You need a set of gauges to check both the high and low side pressures.
How do you know the Freon is full?
Aug 12, 2019 at 5:52 AM
  • 156 POSTS
I checked it with one of the gauges that comes with an AC Pro.
Aug 12, 2019 at 10:56 AM
That's not an indicator. You need a real set of gauges to check the pressures.
You can rent or buy a cheap set to check the pressures.
Aug 12, 2019 at 11:01 AM
  • 156 POSTS
Okay, thank you.
Aug 12, 2019 at 1:18 PM
You are welcome.
Always glad to help.
Aug 12, 2019 at 6:09 PM
