Got a new blower motor and resistor and when I wire it up nothing happens?
217,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
LESLIE MICHELLE GOURLEY
Got a new blower motor and resistor and when I wire it up nothing happens. All fuses are good.
Jan 4, 2023 at 4:42 AM
  • 55,588 POSTS
When you did the blower motor did you replace the speed control resistor as well? Also let's check for power at BLWR fuse under the hood here is a guide that will help and i have included the blower motor speed control location and replacement instructions in the images below.
Jan 5, 2023 at 2:53 AM
There is power at the fuse and I replaced the speed control resistor as well.
Jan 5, 2023 at 3:10 AM
  • 55,588 POSTS
Can we check for power at the red wire at the speed controller (resistor?) Also, can we check for ground at the black wire? here is a guide also I have included the wiring diagrams for the blower motor so you can see how it works:
Jan 5, 2023 at 5:09 AM
