A/C FUSE KEEPS BLOWING
2008 KIA
39,000 MILES • 1.4L • MANUAL
MOSHEEN
  • 15 POSTS
The blower, A/C , heater and rear wiper do not work at all. I tried changing the fuse, but it keeps blowing as soon as I turn the key, all other fuses are intact.
Mar 11, 2017 at 7:23 PM
MOSHEEN
  • 15 POSTS
The car is a Kia cee'd 2008 BD59YEU
The fault original occurred when I put the battery terminal backwards and shorted some fuses. I managed to fix the alternator and radio fuse and they are working fine now. I also checked the heater resistor and that does not look blown or damages. it is just The blower, A/C, heater and rear wiper issues I have. I believe there might be a short somewhere just cannot find it.
Thanks,
Mo
Mar 11, 2017 at 7:30 PM
HMAC300
  • 48,601 POSTS
if it keeps blowing you will have to put a circuit breaker and unplug things to rule out what is doing it. then once you find the problem you'll have to see if it is drawing to many amps etc. Of course it could be a wiring grounding out against the engine block/body so check harnesses as well.
Mar 12, 2017 at 12:42 AM
MOSHEEN
  • 15 POSTS
Thanks, I will give that a go.
Mar 12, 2017 at 1:43 AM
  • 55,770 POSTS
You can by a box of fuses and unplug each accessory one at a time, I would start with the AC compressor.
Best, Ken
Mar 13, 2017 at 7:33 AM
MOSHEEN
  • 15 POSTS
Thanks for the replys, all the fuses seem to be good under the hood and footwell, the only fuse that was blown was under the footwell marked A/C 10A, but every time I attempt to turn the engine it blows, can't seem to figure it out
Mar 13, 2017 at 7:15 PM
  • 55,770 POSTS
I did some digging and found a wiring diagram for you to look at, it seems like the 10 ac fuse goes to the ac control module. Please try to unplug it and retry the system.
Best, Ken
Mar 14, 2017 at 4:58 AM
MOSHEEN
  • 15 POSTS
Thanks ken the diagram is going to be a great help, when you say "ac control module. Please try to unplug" do you mean the dials on the dash and remove the cables from behind the panel.
Thanks again
Mo
Mar 14, 2017 at 5:42 AM
HMAC300
  • 48,601 POSTS
yes that is what he means is the control panel for the a/c you can also have a mechanic scan for codes with his scanner to verify the problem.
Mar 14, 2017 at 5:58 AM
MOSHEEN
  • 15 POSTS
Tried unplugging the A/C panel but it still blows the 10A A/C fuse, scanner does not bring any error or codes.
Mar 14, 2017 at 7:32 PM
HMAC300
  • 48,601 POSTS
a mechanic has to use his scanner it is a pro type it can read all the modules in a car not the ones that are sold in auto parts as they won't do it. if unplugging a module does not work then you have short in wires someplace hitting either body or engine. if anything was recently installed then check that as sometimes screws are put in dash to hold a switch and go through harness
Mar 14, 2017 at 11:17 PM
MOSHEEN
  • 15 POSTS
I took it to a mechanic last week who removed all the codes that came up none of them were relevant to the issue, he checked again for new codes recently and nothing is coming up. So it just a matter of finding the short, the only things that I have changed was battery, cabin filter and air filter. I will check around those areas again for any shorts. Thanks again for you assistance in this matter, dont want to take it to the dealers just yet, otherwise I'll end up throwing money at it.
Mar 14, 2017 at 11:38 PM
  • 55,770 POSTS
Please let us know what you find so it will help others.
Best, Ken
Mar 15, 2017 at 4:29 AM
MOSHEEN
  • 15 POSTS
Hi
Anyone know where I can download for free the wire diagrams for a Kia ceed 2008 1.4
Thanks in advance
Mo
Jun 10, 2017 at 10:03 PM
  • 55,770 POSTS
Just let me know what you need and I will get them for you.
Jun 12, 2017 at 4:53 AM
MOSHEEN
  • 15 POSTS
Hi ken I used above wire diagrams but mine looks different, the 10A/C Fuse also controls the alarm and rear wiper. So I need a diagram so I can isolate the issue I have also added the VIN NUMBER thanks again
U5YFF24128L105255
Jun 12, 2017 at 3:56 PM
HMAC300
  • 48,601 POSTS
from your description your car is not in US or Canada as most kia's here have larger engines . We are more than likely not to have the correct diagrams for that car as you have said the fuse controls alarm and rear wiper in US those are separate circuits.
Jun 12, 2017 at 10:53 PM
MOSHEEN
  • 15 POSTS
I am in the U.K. CAR is only a 1.4
Jun 12, 2017 at 11:03 PM
JASON REEVES
Any luck with this problem I have a ceed 1.6 estate and the same problem with alternator fuse and stereo fuse gone but a.c. and rear wiper keeps popping the fuse
Jul 6, 2018 at 5:57 AM
  • 55,770 POSTS
Can you remove the wire going to the AC compressor and replace the fuse to see if it pops do not ground the lead to the compressor?
Cheers, Ken
Jul 6, 2018 at 7:30 AM
MOSHEEN
  • 15 POSTS
I replaced the fan blower, and that sorted my issue,
Jul 6, 2018 at 8:53 AM
JASON REEVES
Yeah have unplugged it and it still pops the fuse and have unplugged blower motor and still pops fuse .
Jul 6, 2018 at 5:36 PM
MOSHEEN
  • 15 POSTS
Initially when I unplugged my motor it still blew the fuse, but when I replaced the unit, that fixed the problem and no more blown fuses.
Jul 6, 2018 at 6:08 PM
  • 55,770 POSTS
Good to hear, please use 2CarPros.com anytime we are here to help.
Cheers, Ken
Jul 7, 2018 at 3:10 AM
KAMEN
Hi lads I have the same problem a guy turn the straps other way around and blow up the alternator fuse and after that it cause problem to A/C, radio player, rear wipe and front wipes work only on fast mode.
The 10A A/C fuse blows all the time.
Was told that is the Body control module problem, I've changed it but the problem still occurs.
Oct 24, 2018 at 10:00 PM
  • 55,770 POSTS
Yep, Can you unplug the AC compressor and see if the fuse still pops? Please let me know.
Oct 25, 2018 at 10:12 AM
KAMEN
I removed the car bank due to change the fan and saw black relay that respond for the fan, that relay was blown and was causing the problem, so I change it and that sort out the problem in general. Thanks guys very helpful forum could not managed without your advice's!
Nov 17, 2018 at 4:27 PM
  • 55,770 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Nov 19, 2018 at 3:36 AM
