A/C front blower fuse blew three times?
155,000 MILES
CHRISTOPHER HUNT2
So, the A/C fuse under the hood blew three times causing the front A/C to not work at all, while the rear A/C is still blowing nice and cold. Now, the front A/C popped, and the new fuse is not working. I checked all other A/C fuses to make sure it was not one of them to no avail.
May 17, 2025 at 2:59 AM
CHRISTOPHER HUNT2
Also, about 2 years ago I replaced the front A/C blower. This current issue began on the first half of December 2024.
May 17, 2025 at 3:00 AM
  • 55,746 POSTS
It sounds like you have a defective blower unit which unless you have an OEM unit is common. I would try swapping it out again. There is on the front blower motor on that circuit fyi. Let me know how it goes.
May 18, 2025 at 11:43 AM
CHRISTOPHER HUNT2
That is what I also think. I bought a new blower as the wire has voltage. Should receive it tomorrow.
May 18, 2025 at 4:55 PM
  • 55,746 POSTS
Yep, sounds good, it should fix it.
May 19, 2025 at 2:37 AM
CHRISTOPHER HUNT2
It is replaced and working. I replaced it a year and a half ago and had the fuse issue this year which was connected to a bad battery connection after thinking about it. I was offshore when the fuse issue happened a few times and forgot what the situation was when first contacting you. I also fixed the battery terminal issue.
May 19, 2025 at 8:36 AM
  • 55,746 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
May 20, 2025 at 1:50 AM
