Where is the A/C evaporator temperature sensor located?
220,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
ARNOLDFRAC67
I'm look­ing for A/C evap­o­ra­tor temperature sen­sor lo­ca­tion and di­a­gram. Can't find any­thing about where or if it has one.
Jun 29, 2024 at 8:43 AM
STEVE W.
  • 15,404 POSTS
Don't see anything in service data that says it has one and nothing on the circuit diagram.
Jun 29, 2024 at 10:41 AM
ARNOLDFRAC67
So, how does the computer know if the A/C is freezing up, someplace there is one. No mechanic knows anything about it. So pathetic.
Jul 5, 2024 at 4:10 AM
STEVE W.
  • 15,404 POSTS
It controls the temperature through timed cycles and pressure switches. No thermal control through anything other than the pressure switches and the cycling switch. It's a common system used on imports and earlier domestics that didn't monitor the cores. There is no thermal sensor on that vehicle.
Jul 5, 2024 at 5:43 AM
