A/C blowing hot air
121,547 MILES • 6 CYL • 2WD • AUTOMATIC
JMEL6279
This is a Sienna not Sequoia. A/C is blowing hot suddenly, low voltage to the compressor, throwing codes for A/C amplifier and solar sensors, all relays and fuses are good, pressure sensor good.
Aug 21, 2020 at 11:33 AM
What are the specific codes? Let's get this and go from there. There are a couple issues that could cause this. First the low voltage at the compressor. What was the voltage that you found?
Next are the codes so we need to find which they are and we can figure out the next steps. Thanks
Aug 21, 2020 at 11:47 AM
