A/C does not work
2006 CHEVROLET IMPALA
150,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
TGBJR1983
My A/C does not work. I start the car and push the A/C button, it flashes and goes out and the A/C never comes on.
Jun 11, 2018 at 2:47 PM
  • CERTIFIED EXPERT
  • 31,937 POSTS
Often it is a case of low or no refrigerant due to a leak. So the first step is to get the system pressures checked. If system is low, a leak test must be done to locate and rectify the leak, if the system is low, do not just add refrigerant as it will only last a short time as it will not hold presser until the leak is located and rectified.
Jun 12, 2018 at 2:41 AM
