Hvac wiring diagrams please?
90,000 MILES • 2.6L • V8 • 2WD • AUTOMATIC
ROD WILLIAMSON
Driving with A/C on, it is cooling. If I hit a bump it it continues to run but air is warm, hit another rough spot it comes back cool again. It makes a sound when this occurs like compressor is coming on and off. I may drive several miles between intervals.
Sep 14, 2018 at 5:18 AM
I would start by checking the connector at the A/C compressor. The jolt from the bump may be causing the connection to be not good.I attached the location of the connector at the compressor.
I also attached the wiring diagram for you to view. That connector is common for coming loose.
Check out the diagrams (Below). Please let us know what you find.
Jan 22, 2021 at 12:54 PM
  • 55,797 POSTS
it could be the system needs to charged.
https://youtu.be/uZrQCGwXfek
Feb 15, 2021 at 5:11 AM
