A/C cycles cold to hot
114,000 MILES • 5.0L • V8 • RWD
PATMAN41
My car starts off cold when I start driving to work. After nine to ten miles, the air turns hot. If I do not turn off the air, it will cool again after five minutes or so.
This cycle will repeat as I drive during the day.
Hey, it is 105 degrees F in Phoenix these summer days.
Likely some kind of climate control malfunction?
Aug 14, 2017 at 11:30 PM
  • 55,804 POSTS
It sounds like you have a problem with the level of Freon you have either too full or now enough. Here are three guides that will help you do some testing to confirm one or the other as the problem:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
and
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
or
If this checks out it could be a blend door actuator that is giving you trouble. Here is a guide for that as well:
Cheers, Ken
Aug 16, 2017 at 7:15 AM
