A/C cut off
230,000 MILES • 7.3L • V8 • 2WD • AUTOMATIC
TOMCOON
A/C cut off pulling a load, will not come back on until restart.
All fuses and relays seem good, system uses a independent vacuum pump connected to the can. No leaks.
Jul 13, 2018 at 10:11 PM
Good morning.
Do you mean the vents change position or the compressor stops working?
Jul 14, 2018 at 12:47 AM
TOMCOON
No, truck has a separate vacuum pump that is not effected by manifold pressure. A/C stops working.
Jul 15, 2018 at 9:38 PM
Okay.
Is the compressor engaged when this happens?
Can you give me high and low side readings?
Jul 16, 2018 at 6:45 AM
