A/C Controls
250,000 MILES • 8.0L • V8
RONALD P MURRAY
A/C and heat stays on the windshield . Digital controls shows changing when I move to floor or to front controls.
Dec 2, 2016 at 11:58 PM
HMAC300
  • 48,601 POSTS
try pulling HVAC fuse inside truck for sixty seconds with key on then reinstall. it may reset actuator, if not the actuator may be bad make sure your cable is not the problem and is moving control it is on drivers side. see picture the floor duct needs to be removed first.
Dec 3, 2016 at 4:33 AM
