How often should a condenser be replaced?
234,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
YAZIDAN
  • 141 POSTS
The receiver drier is part of the condenser in my car. How much oil needs to be added for a condenser?
Thank you
Apr 30, 2023 at 11:11 PM
  • 55,711 POSTS
This part should be replaced when replacing the A/C compressor. here are the instructions on how to do the job and to help walk you through the steps in the images below. You will need to vacuum down and recharge the system.
This guide can help with that:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
May 1, 2023 at 3:54 AM
