a/c compressor will not kick in,
166,600 MILES • 4.3L • VR6 • RWD • AUTOMATIC
CSEITZ
a/c on 1999 astro van will not run, a/c compressor is only 1 year old, a/c worked fine until I shut it off, when I went to drive the vehicle again it would not kick in, the blower will run when you set it on max a/c but the compressor will not kick in, checked the fuse, relay and they are both good compressor will noit kick in, thank you
Aug 21, 2014 at 4:14 AM
DOCFIXIT
  • 18,828 POSTS
Need to check charge first if you have gauge set hook up and post static readings. If not have a shop do AC check generally @$20-30
Aug 21, 2014 at 4:45 AM
