A/c compressor swap for bypass pulley
250,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
LILNIKITA
Socket wont fit bolt trying to strip,,,what tool should I use
Jan 18, 2015 at 11:10 AM
SATURNTECH9
  • 30,868 POSTS
If your rounding the bolt your best bet would be to get a socket for removing rounded bolts and nuts.I know sears sells a set also other places has them.
Jan 18, 2015 at 11:33 AM
LILNIKITA
Socket wont fit..but now I am locked out with side power locks!! Ahhh...lol
Jan 18, 2015 at 12:41 PM
SATURNTECH9
  • 30,868 POSTS
So are the compressor bolts 13mm bolts ? So your using the correct size socket your using metric sockets?
Jan 18, 2015 at 1:11 PM
CJ MEDEVAC
  • 11,000 POSTS
6 POINT SOCKETS MIGHT BE PREFERRED OVER 12 POINT
DUE TO THE "NEW" ROUNDNESS YOU HAVE CREATED, YOU MAY HAVE TO "TAP" THE 6 POINTER DOWN OVER THE NUT TO SORTA "RE-HEX" IT
THE MEDIC
Jan 19, 2015 at 7:56 AM
