How to remove and install an A/C Compressor?
200,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
RODJAMES
  • 25 POSTS
How to remove and install an A/C Compressor on the car listed above LS model?
Dec 23, 2023 at 7:42 PM
  • 110,248 POSTS
As far as replacing the A/C compressor, it is a little involved because you need to evacuate the old system, recharge and make sure there is PAG oil in the new one.
Here is a link to get you started. It explains in general how it's done. It includes a little more than the manual.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
If you look below, I attached the information from my manual. Note that I attached the directions related to PAG oil starting with pic 8.
I hope this helps. Let me know how things turn out for you.
Take care and Merry Christmas.
Dec 24, 2023 at 11:22 AM
