A/C compressor removal/install
145,257 MILES
MOEFIXEN1
first time changing compressor and don't have a compressor gauge to extract any air in tank. i am going to buy the refill cans an the oil can.saw a video stating both cans go into the same line. so i was wondering if the refill line is were i drain the tank or is there another location to do so,and if i can stick something in the valve stem an let the air spray out.
Jan 2, 2020 at 9:34 AM
Good evening,
It is illegal to vent Freon to air as it damages the ozone layer. You need a recovery machine to remove the remaining Freon.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
https://www.2carpros.com/articles/replace-air-conditioner-compressor
I need the VIN number so I can get the procedure for you. There are 4 different engines for this model.
Jan 2, 2020 at 9:57 AM
