Why does the A/C compressor line get hot?
127,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
JOE1953
  • 809 POSTS
I use a halogen leak detector to find leaks and the detector found one on the ac condenser, the pressure on my vacuum gauge drop from around 40psi to around 20psi. when I check the pressure in the system do I start engine before I connect the gauges?
Aug 18, 2025 at 6:52 PM
  • 55,710 POSTS
It is normal for the A/C line to get hot, please go over this guide to see how the A/C system works.
https://www.2carpros.com/articles/how-a-car-air-conditioner-works
This video will show you how to vacuum down and recharge the system.
https://www.youtube.com/watch?v=4EqdrBVb0sY
Please go over these guides and get back to us.
Aug 19, 2025 at 1:19 AM
JOE1953
  • 809 POSTS
I still have a Freon leak in the system I check the pressure with the engine off the psi was around 40.
Aug 24, 2025 at 2:51 AM
  • 55,710 POSTS
Yep, you have a leak, please start a new question for us to fix it, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Aug 24, 2025 at 3:53 AM
