A/C compressor issues
179,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RAGINGSOUL
  • 54 POSTS
I have the SUV listed above LT model, VIN Z with front and rear A/C controls.
I changed out my A/C compressor clutch due to not turning. A/C was working fine. Two months later (now) the compressor is squealing while engine is running. Much like a power steering pump does when low on oil. I also noticed that I could not hear the clicking sound when the clutch engages.
Question 1; does the compressor just need oil or replaced? If need be I can record the sound but not sure if it would any justice.
Question 2; which A/C Compressor do I purchase? This is what I see but I am still confused as to which one is correct. Here is an example:
FitsGAS; Front; Dual Zone Climate Control with Automatic Controls (you can set a specific numeric temperature) (CJ2), Front; Dual Zone Climate Control with Manual Controls (blue/red dials only), Rear Auxiliary A/C (C69)
OrFLEX Fuel; Front; Dual Zone Climate Control with Automatic Controls (you can set a specific numeric temperature) (CJ2), Front; Dual Zone Climate Control with Manual Controls (blue/red dials only), Rear Auxiliary A/C (C69)
Question 3; The vacuum pump would this work https://www.harborfreight.com/air-vacuum-pump-with-r134a-and-r12-connectors-96677.html
OR
should I purchase this https://www.harborfreight.com/25-cfm-vacuum-pump-98076.html
OR
Just have a shop fill the R134A
I am sure I will have more questions I would prefer to do the work myself and learn than have some one do it for me.
Aug 23, 2018 at 8:22 AM
Good evening.
Do you have automatic climate control?
Once I know I can find the compressor for you.
Aug 23, 2018 at 11:18 AM
RAGINGSOUL
  • 54 POSTS
Hi Roy and thank you for your help. Honestly I am not sure. There are controls on the dash with numbers and temp for both driver and passenger and controls in the back seat. How would I tell? or would the vin number help you out? 1GNEK13Z44J301037
Aug 23, 2018 at 11:36 AM
Okay, that is automatic climate control.
Rock Auto has it for $139.00.
https://www.rockauto.com/en/catalog/chevrolet,2004,tahoe,5.3l+v8,1424247,heat+&+air+conditioning,a/c+compressor,6628
1. Clutch does not need oil. It is a dry running unit. The noise may be the belt slipping across the compressor from a bad tension-er.
2. The rock auto compressor will work.
3. Yes, that is good.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Aug 23, 2018 at 11:45 AM
RAGINGSOUL
  • 54 POSTS
Thank you Roy
I appreciate your help. If I can ask another question or several, the A/C compressor from Rock Auto in the description it states this "Dual Zone Climate Control with Automatic Controls (you can set a specific numeric temperature) (CJ2), Front; Dual Zone Climate Control with Manual Controls (blue/red dials only), Rear Auxiliary A/C (C69)" What does this mean and which dials are they talking about? I know that you can set a numeric number for the front and dials on the ceiling to control the back. Then in that back seat it has a button style temp and video combo. So is this still the correct A/C compressor?
On a side note my wife has seizures and heat will bring them on and a service dog that goes with us. It is imperative that I make as little mistakes as possible. We live in Texas and right now it is 103 degrees so I have to make 100% sure that this is the correct compressor. (Not at all doubting your expertise)
This is the correct one. $139.00 https://www.rockauto.com/en/moreinfo.php?pk=436692&cc=1424247&jsn=564&jsn=564
Aug 25, 2018 at 7:35 AM
Yes, that is the correct one for your car.
You are good to go.
Aug 25, 2018 at 8:13 AM
RAGINGSOUL
  • 54 POSTS
Thank you Roy, you really are a huge help for this old shade tree mechanic. I would also like to post my gratitude on Facebook about you and 2carpros.com. It is nice to see people helping people just to help. It is so awesome sauce. I would like to be able to pick your brain in the future about cars. I also have a 1980 Ford Bronco that I have to rebuild that motor and I have not rebuild a motor in thirty years.
Thank you again Sir.
Aug 25, 2018 at 10:13 AM
You are welcome.
Thank you for the kind words.
Aug 25, 2018 at 10:16 AM
RAGINGSOUL
  • 54 POSTS
Good Day Roy,
If possible I would like to ask a couple more questions on my ChevroletTahoe. I received the A/C Compressor, the orifice and o-rings. Can I go ahead and replace those now even though I have not the equipment to charge the system yet? Also, what is your expertise say about switching out the accumulator? I believe this is the correct one, https://www.rockauto.com/en/moreinfo.php?pk=3914700&cc=1424247&jsn=566
Thank you again for your help it is greatly appreciated.
Jon
Sep 11, 2018 at 12:24 AM
Yes, ask away.
The accumulator is a must to replace since you are opening the system. If you do not you will contaminate the old one which is most likely contaminated now anyway.
Sep 11, 2018 at 12:41 AM
RAGINGSOUL
  • 54 POSTS
Hi Roy
You helped me out earlier this year with my A/C which is working awesome by the way. I have another issue and wanted to know if you would be able and willing to help me out once again?
Thank You for your time
Jon
Dec 5, 2018 at 5:01 AM
Okay, if it is related to the same vehicle, same problem. if it is not, please go to the home page and start a new question. Then any of us can assist you.
Dec 5, 2018 at 6:22 AM
