A/C compressor clutch not cycling
57,000 MILES
EDS240Z
The A/C was blowing warm air. I added dye and found a leak at the condenser and line from compressor to condenser. Replaced both and the line came with a new pressure switch. Vacuumed and charged the system. Getting cold air now but noticed the clutch isn’t cycling on and off. Clutch disengages if I turn off the A/C. Is this normal? What should I check?
Apr 16, 2022 at 1:06 PM
SQM
  • 6,383 POSTS
The clutch should disengage when the AC is switched off. This is a normal operation.
If the clutch was not cycling on or off correctly the air will not get cool.
https://www.2carpros.com/articles/how-a-car-air-conditioner-works
Let me know if you have any questions.
Apr 17, 2022 at 4:19 AM
