A/c compressor bypass
144,450 MILES • 6 CYL • AWD • AUTOMATIC
DEBBIE LYNN BUCKNER
I know that the rotator cuff has started to go bad on my compressor and it needs to be replaced but I cant afford it right now. How can I bypass the AC compressor? Can I just buy a shorter belt or do I have to install one of those pullies? I have 4 people telling me all different things. I just need a right answer before I spend my money.
Aug 27, 2016 at 5:31 AM
HMAC300
  • 48,601 POSTS
you have to go to an auto parts to see if you can match one up it may take a pulley but that is the only way to fix it if you want to jump compressor
Aug 27, 2016 at 5:53 AM
DEBBIE LYNN BUCKNER
The problem I am having is knowing if I need a pully or not. No one has a answer for me. I cant find it online eaither.
Aug 27, 2016 at 6:11 AM
HMAC300
  • 48,601 POSTS
when this is done there is no set way to do it that is why it has to be done at an auto parts to try to find a belt that will fit. like I said it may or may not take a pulley to make it work.
Aug 27, 2016 at 8:20 AM
DEBBIE LYNN BUCKNER
Thank you so much, ill go to autozone tomorrow. Thank you again!
Aug 28, 2016 at 2:01 PM
RENEE L
  • 1,260 POSTS
Please let us know what you find so it can help others.
Aug 31, 2016 at 11:24 AM
