A/C compressor bearing removal
180,000 MILES • 5.4L • 6 CYL • 4WD • AUTOMATIC
ZACH KINN
  • 8 POSTS
Hello, i have got an A/C compressor that I think is still good but the bearing went out In my truck. I've got the cover plate pulled off and the split ring removed but I'm having trouble getting the bearing out. I think it's road dirt, debris, etc. but I don't have that much room to get it out. Any suggestions?
Thanks
Apr 28, 2019 at 8:27 AM
BMDOUBLE
  • 1,139 POSTS
What usually happens is the hub will get damaged because the bearing will lock up and will wear a groove into the hub and gall it up. Sometimes if the damage is not that bad you can walk it off with two screw drivers carefully, but sometimes the damage done by the bearing will be too much and you’ll have to replace the compressor. Hopefully yours is not too bad.
Apr 28, 2019 at 9:08 AM
ZACH KINN
  • 8 POSTS
I'll try that. I appreciate it.
Apr 28, 2019 at 9:33 AM
BMDOUBLE
  • 1,139 POSTS
No problem! Good luck!
Apr 29, 2019 at 5:35 AM
