A/C blowing hot on driver's side
91,000 MILES • AUTOMATIC
SHEIM
The air on the drivers side is blowing hot and the passenger side is blowing cold then warm then cold again.
Jul 4, 2020 at 5:03 AM
Good afternoon,
Can you check the freon pressures for me and give me the high and low side readings?
The procedure for the blend door is below and there are pictures as well. Number 16 is the one and is behind the glove box.
DOOR MOTOR
AIR MIX DOOR MOTOR : Removal and Installation - Air Mix Door Motor LH
REMOVAL
1.Remove the front floor duct (RH). Refer to "Exploded View" See: Air Duct > Removal and Replacement > Exploded View.
2.Disconnect the harness connector from the air mix door motor LH.
3.Remove the air mix door motor LH screws and the air mix door motor LH.
INSTALLATION
Installation is in the reverse order of removal.
Jul 4, 2020 at 6:44 AM
