A/c cold at idle but goes to ful heat on acceleration
2002 CHRYSLER CONCORDE
80,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
BILLPOLKJR
We replaced all 3 door actuators yesterday. Now, at idle, the air is cold and when turned to heat, it stays cold. When accelerating, the air goes to full heat (even though the temp control is still on full cold). as soon as it goes back to idle, the temp goes back to full cold.
Sep 10, 2015 at 12:50 AM
HMAC300
  • 48,601 POSTS
scan for codes it's your blend door screwing up so either it's wired incorrectly due to replacing module or the control head is bad which can only be found via scanning. a pro will have to do it.
Sep 11, 2015 at 10:56 PM
