A/C clutch not engaging
101,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
SCOTTY ZOOK
When I turn on my A/C, the compressor doesn't kick on. And there is this red flashlight flashing that looks like a thermometer and an engine with a red square outline. What is that for? Why won't the A/C turn on?
Aug 7, 2019 at 8:09 PM
Good morning,
You could be low or out of Freon. You need to have the system pressures tested to see if enough Freon is in the system to engage the low-pressure switch.
As far as the lights, can you upload a picture of the lights for me to see?
Aug 7, 2019 at 10:22 PM
