Car was blowing cold air with no leaks, however it was making a rough sound. The clutch had a slight wobble.
Replaced the compressor and clutch. Then recharged the system and checked again for leaks. (No leaks found)
But now the clutch will not engage. If I jump the clutch it will engage. I checked the rely and it is also okay.
Any thoughts? It is hot in mid-Missouri!
Sep 2, 2018 at 12:55 PM
