air Conditioner clutch
269,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
NIGEL ALLISON
The clutch plates are grinding, turning when system is off, noisy.
May 25, 2016 at 4:37 AM
HMAC300
  • 48,601 POSTS
Check to see if clearance on clutch plate is correct if not it will burn up. It should be .014-.033" measured in three places if not add shims. See picture.
May 25, 2016 at 5:11 AM
NIGEL ALLISON
Okay, That was useful information. Thank you.
May 25, 2016 at 9:07 AM
