a/c cluch does not engage and compressor does not start
109,000 MILES • 3.2L • 6 CYL • FWD • AUTOMATIC
ROSIEACCURA
Fan on high, a/c turned on, a/c cluch does NOT engage and compressor does not start.
Tried again 1 hour later, compressor goes on and cooling is normal. Relay or something else?
Jul 30, 2015 at 11:38 AM
  • 110,248 POSTS
It could be a relay. Check to make sure the wiring at the clutch is good. If this happens again, check to see if the compressor clutch is getting power. If it is, the clutch is going bad. If there is no power, check connections and the relay, as you mentioned.
Jul 30, 2015 at 1:40 PM
ROSIEACCURA
THANK YOU FOR YOUR PROMPT REPLY. YOUR ADVISE IS APPRECIATED.
Jul 31, 2015 at 5:22 AM
  • 110,248 POSTS
Glad to help. Please remember, if the Freon is low enough, the low pressure switch won't engage the compressor. That's just another thought.
Aug 2, 2015 at 1:50 PM
