A/C bypass solutions?
188,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
RYDER1477
  • 48 POSTS
I swapped a 2003 Impala 3.8L with a 2004 Impala 3.8L. I don't want to run the A/C (plus the connection doesn't line up) so i just dead ended the connector that comes off the radiator on the passenger side. Will this setup work or do I need to hook up this line regardless?
Nov 17, 2024 at 7:59 AM
  • 55,732 POSTS
Yep, the part in the image with the arrow is an A/C line, if you are not running A/C it can be removed. Let us know if you need anything else.
Nov 18, 2024 at 3:27 AM
RYDER1477
  • 48 POSTS
Can i just remove the entire line from the rad end of it also?
Nov 18, 2024 at 3:54 AM
RYDER1477
  • 48 POSTS
Also, how hard is it to fix the 'TRAC' Control? It snowed last night and on the way into town, i hit a patch of snow covered road and it was all over the place. Had to seriously reduce speed and it would not stay straight. Would the TRAXC control have that much impact on the handling & steering of this car? If so, how can i fix it?
Nov 18, 2024 at 9:37 AM
  • 55,732 POSTS
You should be able to remove all parts of the air conditioner and be okay. Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Nov 19, 2024 at 1:31 AM
