ok you didn't give a good description to begin with. now you say the compressor cycles so it's not bad probably . what has happened Freon has leaked someplace and it needs to be checked where electronically is best then fixed and if system has been like this for quite a while then the drier has to be replaced as well then the system has to be pumped down (evacuated)for at least a half hour prior to filling.
Apr 12, 2014 at 12:06 AM
