A/c blows hot air
2012 HYUNDAI TUCSON
122,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
HALL92345
My A/C blows hot air. The guage readings with A/C and engine on and compressor clutch engaged are: low side 90 high side 160 at 85 degrees. What could be wrong?
Jun 11, 2019 at 9:33 AM
JIS001
  • 3,412 POSTS
Wow, your low side is pretty high and the high is low. This would indicate a bad compressor. Since the compressor seems like it failed you would need to replace the compressor. The condenser has the drier. You can replace the bag inside the condenser but I recommend you replace the whole condenser and flush the whole system.
Jun 11, 2019 at 6:09 PM
