A/C blows cold then warm
154,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
ARAJ
Replaced A/C compressor and 2 days after A/C been intermittently blowing cold then warm. No certain pattern, just does it throughout the day. Sometimes I'll turn off A/C and turn it back on and A/C will blow cold, but after a while will blow be warm again and comes back cold.
Jul 3, 2020 at 12:09 PM
Good morning,
Did you change the dryer and evaluate the system for about 45 minutes? It sounds like you may have moisture in the system.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Can you tell me the high and low side pressures while the engine is running? You can rent a set of gauges at a parts store if you do not have a set.
Jul 3, 2020 at 8:17 PM
