A/C blows cold and strong for 15 minutes and then blows cold and very weak until I turn off the car?
2008 HONDA CIVIC
140,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
LUKECHACKO
When I start up my car, the A/C is blowing cold air very strongly and has no issues with air flow. After about 5-15 minutes of driving the air flow will nosedive to almost no air flow even at the highest fan setting. I will feel just a tiny bit of cold air flowing out at the highest fan setting and it will remain like this until I shut the car off for twenty or so minutes and then it will repeat the same cycle. The cabin air filter is clean, air line PSI is optimal. I don't know the next step to check after this.
Jul 27, 2023 at 6:27 AM
  • 55,456 POSTS
So, what happens is if the A/C system is just a little low on refrigerant the low side pressure drops too low and ices up the evaporator which restricts the air flow. I would add a small amount of refrigerant to see if that fixes the problem. Please watch this video to help you get the pressures correct:
https://youtu.be/4EqdrBVb0sY
And please go over this guide:
https://www.2carpros.com/articles/comprehensive-guide-troubleshooting-intermittent-automotive-air-conditioner-problems
Please go over these guides and get back to us.
Jul 28, 2023 at 4:53 AM
