A/C blowing only hot air
2006 CHRYSLER PT CRUISER
150,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
LAURA MESSENGER
Our compressor sounds like it is engaging, actuators seem to be working properly, just recharged the refrigerant. I am at wits end.
Aug 19, 2018 at 7:26 AM
Good afternoon.
Do you have a set of gauges to give me the high and low side reading so I can see if the system is working correctly?
Aug 20, 2018 at 6:16 AM
LAURA MESSENGER
I do not, I am sorry. Today it is blowing colder the farther away from the driver side today.
Aug 20, 2018 at 8:06 AM
See if you can borrow a set. If not, you can rent a set at a parts store.
I need those readings to help you.
Aug 20, 2018 at 8:08 AM
