A/C blowing hot air
1989 LEXUS GS 300
219,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRISTA DICKSON
  • 150 POSTS
the A/C in this car has not worked since i bought the vehicle. the guy said maybe it had a leak. i took the car to Pep Boys yesterday to get a free A/C check because i don't own a gauge to get high side readings. the guy came out got me i have filled it up with Freon he verified that it had Freon and the compressor clutch engages correctly. so i was thinking it was fully functioning because visually it engages and disengages like its supposed to be. he said that the levels are about where they should be but that they are supposed to drop at a certain point and that they were not doing that . keep in mind this is a free check and i didn't have the $61.99 for a better check. he suggested that maybe there was a block or something else wrong with the compressor and suggested doing that and replacing the dryer.i have replaced an A/C compressor before on another vehicle, but i don't know all there is to learn about A/C systems so i don't really understand what could be the problem. it blows fine and decent just hot air even when i filled it all the way up. it is like a blow dryer to the face and here in Texas summer heat it is getting a little unbearable i need to get it working ASAP and don't have much money to spend so i want to be sure of what the problem is.what else could have failed inside the compressor and what would be the cheapest way to go about getting cool air back?
Jun 30, 2019 at 3:22 AM
  • 55,423 POSTS
It does sounds like the compressor is bad which is common. To be sure you need to see the high side reading when it is running. Here is a guide to help check and to replace the compressor if there is low high side pressures:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
and
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Jul 1, 2019 at 7:18 AM
