A/C blowing hot air
176,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
JOE THE MARINE
  • 86 POSTS
Just put in a blend door actuator in last week from AutoZone. all vacuum lines are new, when and checked out okay. Turn on the A/C, after the new door was installed, ,nice cold air came out and ran the car for 10 minutes. Today turned the A/C on, same problem is happening as before, could this be the the new actuator that i put in? I hope not, because what a headache it was to get at and bruised knuckles and sore back. What do you think? Is there any way to check? I do not know it's the same problem. Thanks for any info on your end . Help, hot in Phila PA., 85 degrees.
May 27, 2020 at 12:42 PM
Good morning,
Can you hear the door moving back and forth when you command heat and A/C?
Do you have gauges to test the high and low side pressures? It could be a Freon issue
Is the compressor clutch engaged?
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
May 27, 2020 at 11:14 PM
