A/C blowing hot air
2004 CHEVROLET 1500
200,000 MILES • 4WD • AUTOMATIC
MATTHEWDEWAYNE
My air was working before, I took it to the shop to get the rear main seal fixed and when I got the truck back my air started blowing hot air. I got a new climate control module and it still was blowing hot air. What else can it be?
Aug 5, 2018 at 4:35 AM
Good afternoon.
Did you see if you have any pressure in the Freon system? It needs a minimum of 20 lbs to close the low pressure switch.
Also, check to see if any wiring was disturbed at the compressor.
Aug 5, 2018 at 7:28 AM
