A/C blowing hot air
68,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
TEXASS
EVAP drips condensation, compressor engages, 1234 refrigerant showing charged, engine fan blows, all fuses good. Next steps?
Aug 25, 2021 at 3:36 AM
  • 110,248 POSTS
It sounds like the A/C is working. What I suspect is the blend air door isn't working properly. The blend door is what is responsible for the air temperature entering the vehicle. I would suggest removing it and seeing if it responds when the temperature is changed from hot to cold and back again. If you find it is bad, here is a link that shows in general how one is replaced:
On your vehicle, it is referred to as a temperature valve actuator. Now, there is a difference between automatic climate control and manual climate control. I am going to provide the directions below for replacing the actuator for a manual system. If you have an automatic system, let me know.
The last pic is the recalibration procedure.
Aug 25, 2021 at 1:32 PM
TEXASS
Thanks for the info. The gauge that came with the r1234 showed green but I gambled and added some refrigerant anyways. That did the job and it's blowing cold now. Hopefully it's a very slow leak.
Aug 25, 2021 at 9:07 PM
  • 110,248 POSTS
Excellent! I'm glad to hear you got it working. I know where I am, we really have needed it the past few days. LOL
Take care and please feel free to come back anytime in the future. You're always welcome here.
Aug 26, 2021 at 1:12 PM
