Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Trailblazer
Climate Control
Blower Fan
Replace/Remove
A/C blower motor replacement
2002 CHEVROLET TRAILBLAZER
260,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
NOLAMAGICK
MEMBER
I recently had my auto's motor blower replaced (underneath and behind glove compartment). Will that/did that cause a loss of R134a (Freon)?
Mar 11, 2022 at 5:45 PM
Experienced Mechanic
Good morning,
I attached the procedure for you for the replacement. It is located under the right side of the dash and is easily accessible.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
As far as a loss of Freon, no. There are many other components that can cause the loss of Freon.
You will need to have a dye installed and charge the system and use a good bright LED light to find the leak.
https://www.2carpros.com/articles/air-conditioner-leak-detection
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Let us know if you have any other questions.
Images (Click to enlarge)
Mar 11, 2022 at 9:09 PM
NOLAMAGICK
MEMBER
You're Awesome! I just discovered your YouTube site and I plan on becoming a regular viewer. Thanks again for your reply, and for such a quick reply!
Mar 12, 2022 at 1:20 AM
You are welcome.
Always glad to help.
Mar 12, 2022 at 8:42 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
