A/C not blowing cool air
1997 GEO TRACKER
145,000 MILES • 1.6L • 4 CYL • 4WD • AUTOMATIC
1997GEO
Out of the blue, A/C is blowing hot air. The A/C compressor is engaged and turning. The A/C compressor discharge temperature is very hot (normal, I do not have a discharge gauge to measure the pressure). The A/C compressor suction side temperature is slightly above ambient temperature. Normally, the A/C compressor suction side temperature is cool to cold to touch when A/C blower is blowing cold air. For the pass three years I have had to add three to four ounces every two to four months. I added a full four ounce can of FJC stop leak, but that did not help.
Any suggestions would be greatly appreciated.
Thank you,
Ken
Nov 4, 2017 at 5:00 AM
  • 55,399 POSTS
It sounds like the system is low once again. I would find the leak and fix it because stop leaks rarely work.
Here is a guide to help you see if the system is low:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
or
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Check this out.
https://www.2carpros.com/articles/air-conditioner-leak-detection
Here is a guide on AC system not working:
Cheers, Ken
Nov 5, 2017 at 12:13 PM
