A/C blower is not working?
55 MILES • 1.2L • 4 CYL • 2WD • AUTOMATIC
MAKANAKI007
I have checked all the fuses and the power is good. I checked the positive and the negative lights in the blower is active but not working.
Jun 29, 2023 at 4:52 PM
  • 55,583 POSTS
blower is active but not working. so, you can hear the blower working and there is no air coming from the vents? If so, it sounds like the mode actuator is not working.
Here is a guide to help and instructions on how to fix the problem in the images below:
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jun 30, 2023 at 5:26 AM
MAKANAKI007
The blower is not working.
Jun 30, 2023 at 5:31 AM
  • 55,583 POSTS
The blower is controlled by a HTR 50-amp fuse under the hood, ground and the AC amplifier. Here are the blower motor wiring diagrams so you can see how the system works.
This guide can help you check for power and ground:
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Here is how to replace the blower motor which usually goes bad and the location of the AC amplifier. Check the connections at the blower motor for heat damage as well. Check out the images (below). Please let us know how it goes.
Jul 1, 2023 at 4:26 AM
