A/C and radio lighting
157,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
QUINTDVR
For more than three months, radio continues to play while engine off and keys out. Now as of yesterday when turning on radio and/or A/C, they do come on but there is no display showing on either. Noticed that after five to ten minutes, the displays do come back on to see. Ideas?
Aug 8, 2018 at 4:00 AM
  • 55,789 POSTS
The illumination is handled by the BCM which sounds like is having an issue. I would disconnect the battery and remove the BCM to look for corrosion or water damage at any of the pins on the electrical connectors.
Here is the wiring diagrams so you can see how the BCM ties in and the location of the BCM as well.
Check out the diagrams (below). Please let us know what you find.
Cheers, Ken
Aug 10, 2018 at 5:08 AM
QUINTDVR
Re-seated BCM connectors and seems to have worked. YES! Thank you.
Aug 14, 2018 at 4:49 AM
  • 55,789 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Aug 15, 2018 at 6:37 AM
