A/C and heater not blowing out correct vents?
200,000 MILES • 4WD • AUTOMATIC
KADEWR
The A/C and heater will blow out the defrost vent regardless of what I set for it to blow out of and automatically alternates to blowing out the main vents and it continuously alternates between the vents, swapping about every 10-20 seconds. The only exception is that about every 2-3 weeks It will only blow out the main vents but only blows at about 1/4 of the max regardless of how high or low I set it to blow, then after about 2-3 days it goes back to alternating between vents.
Sep 18, 2024 at 12:31 AM
  • 110,248 POSTS
The mode door actuator is responsible for the air flow direction. Chances are it has failed or is failing.
First, take a look through this link to see if anything is helpful:
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Next, I have attached pictures below showing the actuator location and the directions for replacement. Note that this if for a manual climate control system. If you have automatic climate control, let me know.
Also, I placed the letter I in one pic and highlighted it. That is the start of the installation process. The very last picture provides the recalibration procedures.
See pics below. Note: The arrow in the picture's points toward the front of the vehicle.
Sep 18, 2024 at 11:31 AM
