A/C and heater blower motor not working?
148,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
B985
My problem is that my blower motor is working but I have no power at the connector. I checked fuses and relays and they’re good. I changed the blower motor resistor as well, that is good.
Jun 21, 2023 at 7:43 AM
  • 110,248 POSTS
If the fuses are good and have power to and from them and the relay tested good, either the power supply wire is bad or the relay itself is not getting the power and ground it needs.
I attached two pics below. If you haven't already, confirm there is power to and from the fuses. If there is, then remove the fan relay. Take a jumper wire and jump connector pin 30 and 87. That should cause the blower motor to turn on. If it doesn't, then the wire has an open.
If you look at the relay, each pin will have a number (85, 86, 87, and 30). 87 and 30 are the secondary side and the ones I need you to jump.
Jun 22, 2023 at 1:45 PM
