A/C blows hot air when outside temperature goes above seventy five degrees
70,000 MILES • 6 CYL • 4WD • AUTOMATIC
BYRDSMOM
When the temperature outside is under 75 degrees the A/C runs perfectly, nice and cold.
As soon as the outdoor temperature goes above that the A/C blows out only really hot air and I can hear the compressor turning on but it shuts back off.
Sep 18, 2018 at 1:35 PM
Good morning.
Do you have a set of gauges to monitor the high and low side of the system?
Good possibility it has to do with the pressures but need to see them so we can further help you.
Sep 18, 2018 at 6:58 PM
