A/C not working properly
94,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
MIKE WILSON6
A/C blows cool in cool weather. When the weather outside reaches temperatures in the 80's and above, the A/C blows lukewarm air.
Mar 30, 2021 at 4:17 AM
More than likely this is low on Freon. We need to check the pressures to be sure. You can rent a set of gauges from a parts store.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
The is probably a leak but you may be able to just fill the system if the leak just started and that will buy you some time. Here is a guide that shows how to do that:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
However, I would strongly suggest we start with the pressures just to make sure the compressor is not damaged.
Below is a chart of proper pressures based on ambient temp. Let me know if you have questions. Thanks
Apr 1, 2021 at 3:29 AM
MIKE WILSON6
Thanks for the information; very helpful.
Apr 1, 2021 at 8:06 AM
You are welcome. Let us know what happens and we can go from there. Thanks
Apr 2, 2021 at 10:06 AM
