Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Sebring
Climate Control
Air Conditioner
Hose
Leak
A/C low side hose leaking
2002 CHRYSLER SEBRING
100,100 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
JRBIZJAK
MEMBER
Leak in low side hose in front of A/C unit. O-ring?
Jun 28, 2018 at 6:35 AM
Experienced Mechanic
Good evening.
I need to see some pictures to determine if the hose is leaking or the o-ring.
Can you post some pictures?
https://www.2carpros.com/articles/air-conditioner-leak-detection
Jun 28, 2018 at 10:15 AM
JRBIZJAK
MEMBER
Looked like leaking from connection.
Image (Click to enlarge)
Jun 29, 2018 at 1:42 AM
Correct. Recover the Freon and vacuum down and remove the connection. It may take o-rings or a flat seal. Make sure the area is clean of all debris before installing it.
Jun 29, 2018 at 2:14 AM
JRBIZJAK
MEMBER
Thanks.
Jun 29, 2018 at 3:39 AM
You are welcome.
Jun 29, 2018 at 6:31 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
