A/C turns off
125,000 MILES
SHERILYN FRANKLIN
  • 90 POSTS
As soon as I turn my A/C on, it turns off.
Aug 13, 2018 at 7:34 AM
Good afternoon.
What turns off? The compressor or the blower motor?
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
Aug 13, 2018 at 8:43 AM
SHERILYN FRANKLIN
  • 90 POSTS
I do not now, the dash just says AC off.
Aug 14, 2018 at 2:57 PM
That is the compressor.
You would need to check the Freon system. You will need a set of gauges to see if there is enough pressure in the system for it to work. If you do not have enough pressure, the system will switch off to protect the compressor.
https://www.2carpros.com/articles/air-conditioner-leak-detection
Aug 14, 2018 at 8:31 PM
SHERILYN FRANKLIN
  • 90 POSTS
Do you mean I need to put Freon in it?
Aug 15, 2018 at 3:41 AM
SHERILYN FRANKLIN
  • 90 POSTS
Thanks.
Aug 16, 2018 at 2:59 AM
Yes, you need to add Freon.
Aug 16, 2018 at 3:20 AM
SHERILYN FRANKLIN
  • 90 POSTS
I added two cans of Freon and the pressure gauge never moved, stayed at zero. The compressor was running. The dash still red A/C off.
Aug 16, 2018 at 12:23 PM
Okay, the next step is you need a set of gauges to see what the pressures are on both the high and low side.
The gauge on the can is not telling us anything. You can rent a set of gauges at a parts store or you can buy a cheap set at Harbor Freight.
Aug 16, 2018 at 11:25 PM
SHERILYN FRANKLIN
  • 90 POSTS
I cannot use the gauge that came with the can?
Aug 17, 2018 at 4:14 AM
No, that does not tell me the high side that I need to see. You need a set that can read the high and low side pressures.
Aug 17, 2018 at 4:57 AM
SHERILYN FRANKLIN
  • 90 POSTS
What are the gauges called?
Aug 17, 2018 at 11:12 AM
Air conditioning test gauges. You can rent them at a parts store.
You can also buy a set a Harbor Freight.
Aug 17, 2018 at 11:13 AM
You are welcome.
Keep us updated.
Aug 18, 2018 at 4:30 AM
SHERILYN FRANKLIN
  • 90 POSTS
Okay.
Aug 18, 2018 at 4:32 AM
