goes to defrost
280,000 MILES
TIMOTHY HARGERS
When I accelerate with my air conditioner on the AC doesn't blow the same
Aug 30, 2016 at 6:44 AM
WRENCHTECH
  • 20,758 POSTS
It is switching to defrost.
The mode selection is done through a series of air doors that are operated by vacuum. When there is either a partial or total loss of vacuum, the system will default to either defrost or on some vehicles, heat. Acceleration can also have an effect on the doors for the same reason.
Look under the hood for a small black plastic hose coming through the firewall. Follow it to the vacuum source looking for any breaks, cracks or leaks. Also follow any other lines that branch off because they may go to a vacuum reservoir (storage tank) and a leak there will cause the same problem. Using a vacuum gauge to determine if you have full vacuum at any given point is the best way to find it. You can cut into the line anywhere and splice it back together with a piece of vacuum hose. Find the broken line, you found your problem.
Apr 19, 2021 at 8:02 AM
TIMOTHY HARGERS
Thank you so much i will look for it.
  • 55,837 POSTS
Here is a guide that can show you what to look for:
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Please let us know what you find so it will help others.
Best, Ken
