compressor turns on but no cool air. it took two cans of Freon the small ones just blows hot are and there is no pressure coming out of lower line.
Sep 21, 2016 at 4:52 AM
HMAC300
✓Experienced Mechanic
what Freon did you use this system takes r12 not 134. although it can be adapted to your system it may be a bad connection not reading any pressure or Freon all went out as fast as you put it in. have a local professional take a look at this.
