Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Colorado
Climate Control
Air Conditioner
Not Working
A/C not blowing cold air
2005 CHEVROLET COLORADO
358,000 MILES • 3.5L • 5 CYL • 2WD • AUTOMATIC
JOSH PURVIS
MEMBER
1 POST
My A/C only blows hot air.
Jun 29, 2020 at 8:51 AM
Experienced Mechanic
Good evening,
Does the compressor engage when you command A/C?
Do you have a set of gauges to test the high and low side of the system? If not, you can rent a set at a parts store.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
I attached a wiring diagram for you to view of the compressor. If you have a test light and volt meter, we can do some testing.
Check the fuses listed in the fuse block. Check them for power on both sides.
Images (Click to enlarge)
Jun 29, 2020 at 9:11 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
